Two black wires and one white in old ceiling fixture ?
Received 0 Votes
I'm replacing an old ceiling fixture and Found it wired up with 2 black wires along with the white wire.
The new light fixture is just the white and black with a ground.
The light switch for this old fixture also lights up another light I close by.
Do I wire the 2 existing black together then attach to black on new light ?
In order to have two black wires and only one white there you would have to have conduit. Is that correct ?
Normally that would have been wired with two cables.... a black and white wire in each.
Could the second white wire be broken off or hidden ?
Can you post a picture of the box and wiring ? http://www.doityourself.com/forum/el...-pictures.html
What is in the box? Two wires under a single screw is not code compliant; you need to connect those two wires along with a third (pigtail) with a wire nut in the box and then connect the pigtail to the fixture.
