Harbor Breeze fan receiver replacement
Old 08-12-17, 04:15 PM
Greetings,
The receiver inside my fan has gone bad and I'm trying to replace it with a universal unit, unfortunately the one inside the fan seems to have the motor capacitors integrated and I don't know how I could go about doing this.
I'm attaching pictures of the original receiver and fan harness, so far I can identify all the wires except from the red, gray and yellow going into the motor.
My new receiver only has a black, blue and white wires coming out, I can wire the blue and white for the light but don't know how to wire the black and white for the fan.
Thank you.
Size:  26.1 KBName:  P_20170812_170140_vHDR_On.jpg
Old 08-12-17, 05:00 PM
You cannot substitute a universal remote system in place of the one you have now.
Your current DC remote receiver switches the capacitors in and out as needed. A universal one cannot do that.
Old 08-12-17, 05:06 PM
Is there a way I could add a new capacitor to make it work? The original receiver can set the fan to 6 different speeds, I don't really care about that, I would be fine with 1 speed and light control.
Old 08-12-17, 05:18 PM
I don't have the wiring diagram to that receiver and would highly doubt it's available online.
Old 08-12-17, 05:34 PM
Well thanks anyway. I'll have to find another solution, I couldn't find a replacement receiver anywhere online.
Old 08-12-17, 05:49 PM
What's the part number on the receiver.
Old 08-12-17, 06:25 PM
Model: Dawnsun fd30-h02r.
Old 08-12-17, 06:53 PM
That's not an fd40.... is it ?
Check out replacement remotes.
replacement remotes/Harbor-Breeze/Ceiling-Fan-Kits/
Old 08-13-17, 08:49 AM
It's not, it says fd30. I found an fd40 online for $30 might be worth the shot.
Old 08-19-18, 09:26 PM
Did you fix youf fan?
Hi.
I have this same problem with Dawn Sun receiver FD30. Did you manage to get your fan fixed? Did you find the FD40? Did it work? I cannot find replacement, either.
Thank you!
Old 08-19-18, 11:25 PM
Welcome to the forums.
That member is not watching this thread but he will get a notification of a PM (private message).
Click on the member name and send him a PM.
I happened across this site recently.....
replacement remotes/harbor-breeze-fan30r190wa-ceiling-fan
