Hunter ceiling fan watt limiter removal
Old 08-17-17, 10:33 PM
I read many post on the internet that said if I removed the watt limiter from the fan it would stop the lights from staying on or flickering. I cut the wires and removed it. there were 2 wires, I think a black and white. I figured out where those go but then there were 2 pull chain wires. Different posts said to replace the switch. I did that but I don't know where the 2 black wires from the switch go. I found somewhere that the bottom wire goes with the other black wires coming from the lights into the orange wire nut but where do I connect the top switch wire to? Please help.
