Removing stuck light bulbs
Old 09-06-17, 10:26 AM
I have a three bulb flood light fixture in a closet that has two bulbs that refuse to turn so that I can remove them. Do you have any suggestions as to what I might try to get them to come out?
Old 09-06-17, 11:48 AM
Received 3,877 Upvotes on 3,475 Posts
A three bulb flood light fixture..... in a closet ?? Actually working ?
Make sure power is off and keep turning the bulb in both directions to loosen it.
Sometimes a spray lubricant can help but since your sockets are up... it may not help.
Old 09-06-17, 03:34 PM
Received 27 Upvotes on 21 Posts
Wink
A paper bag, hammer, and pliers come to mind.
Old 09-06-17, 04:37 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
I had to fix two fixtures with stuck bulbs. eventually the glass broke off and a pair of sharp needle nose pliers finally got the base worked loose.
Years of not changing and some light corrosion stuck them in there real good.
Old 09-06-17, 04:54 PM
Norm201's Avatar
Received 715 Upvotes on 636 Posts
Break the bulb use a raw potato be sure electric is off.
