LED MR16 to GU10
Old 09-29-17, 05:27 AM
LED MR16 to GU10
Hello. I have changed 6x MR16 Halogen bulbs for 6 LED. They started flashing, so I thought I needed a new adapter, but having pulled a light fitting down to look, I find that each bulb has its own plug (Hopefully I can get an image up to view). I just wondered If, instead of changing the current 240w adapter to one compatible for the MR16 bulbs, I could just get GU10 connectors I could insert in to the present plugs?
I can't upload an image it seems.The individual plugs (one per bulb) are about 2cm in length with two elongated connectors [ I I ] inside. Is it possible I could swap these out for ones with GU10 connectors?
Old 09-30-17, 01:22 AM
Received 3,877 Upvotes on 3,475 Posts
Welcome to the forums.
Follow the directions here for pics.... http://www.doityourself.com/forum/el...-pictures.html
Your problem is your fixture's power supply was designed to supply a heavy current for the halogen bulbs. Now you've removed the needed load and the power supply can't stabilize. As a test.... put in the 5 LED bulbs along with 1 halogen bulb.... the fixture should work correctly.
If that is the case then you need to replace the power supply with one to run LED bulbs.
Old 09-30-17, 04:26 AM
This is the plug and lead for each MR16 bulb fitting.
Old 09-30-17, 04:29 AM
Hello..Thanks for responding. The pic thing I sorted, it was just me being an idiot . I have an LED transformer, I just wondered if it would be easier/possible to just swap these plugs that the Light fittings are attached to for some GU10 ones
Old 09-30-17, 12:27 PM
The black plug looks like a proprietary connector for your fixture. That would have to be reused which means you would have to cut that wire and splice on a different lamp socket.
Old 09-30-17, 03:24 PM
That's fine..I was just concerned that doing so would short something out..I am a bit of a novice
Old 09-30-17, 03:33 PM
Since you are dealing with AC... there is no connection polarity.
Small wire nuts will be ok for the splice covering,
Here is exactly what you want.... and there are others.
AspenTek-110-250v-Socket-Adaptors-Connector
Old 09-30-17, 03:36 PM
That's great. Thanks mate
Old 10-02-17, 05:40 AM
Hello..Sorry to bother again. I got some GU10 connectors (not ones in link but the same) and connected the plug to one, but when I plug it in and insert a bulb there is nothing. I have tried two of the GU10 connectors and different bulbs with no effect...Not sure why or what to do.
Old 10-02-17, 11:03 AM
You have a fixture with an AC ballast to run halogen bulbs.
Therefore you need LED bulbs that will run on 12v AC.
Old 10-03-17, 04:19 AM
Size:  95.4 KB I have a 240v transformer, My whole problem was that I wanted to change to LED from Halogen but the 12v LED MR16 bulbs I have don't work. Now the 240v LED GU10s don't work because I changed a connector for the bulb? This is getting frustrating
Old 10-03-17, 12:28 PM
Ok.... in looking at your ballast in the picture I see what looks like a rating of 35-150watts. I'm fairly certain that means your ballast requires at least a 35 watt load to operate properly.
Old 10-04-17, 05:25 AM
Yes..Somewhere in the back of my mind was the idea that just 1 bulb may not work. Thanks mate..Btw..If I had to replace the transformer to run 6x 4w GU10 bulbs, and possibly 6x Halogen GU10 should I need to...What would you recommend?
Old 10-04-17, 05:53 PM
You need to add up the total wattage.
6x4= 24w for the LED's.
6x?= ?w for the halogens.
That supply should be able to run both.
