Intermittent problem with outdoor light/PIR
Hi, newbie to the forum here...I am trying to repair an external light with PIR, up until now the PIR has not been working but the light would work intermittently when switched on, I have tested the bulb in another lamp indoors and firstly was also intermittent then stopped working altogether, I replaced the bulb out side with one I know is working...nothing... I tried a different one in case there was an issue with the voltage...again nothing, I cannot see any loose wiring having partly dismantled the light but am baffled as to where I go next....
Many Thanks ...
Many Thanks ...
I would just replace the unit. New ones are inexpensive and you can even get a LED one for about $30.
I am a bit fussy on my decor so know a replacement would be a bit more than this but have considered this, is there anything I can check before doing so that would ensure the problem is on the light not on the switch/wiring etc ?
