Kitchen LED lighting - connection/wiring
Old 10-23-17, 06:25 PM
Question Kitchen LED lighting - connection/wiring
Previously in my kitchen (under the counters) we had neon lights (connected directly from the wires out of the wall), see the image.
Now I have removed them and want to replace them with new LED light tracks, but the ones I found have a standard outlet connection.
Usually this is simple - pass the wires into a standard receptacle box and plug in the lights - done it a thousand times.
However, the lip under the counter is really small and cannot hide the size of a standard receptacle - so it will look really ugly - and I don't want to have wires coming down from under the counter plugged into the receptacles I use daily for my appliances.
So I am looking for a solution that will allow me to hide the wire under the counter top and somehow connect to my lighting... for example is there such a thing as a "slim" receptacle box (I have not seen one), or can I just connect a plug at the end like this:
https://www.homedepot.ca/en/home/p.2-pole-3-wire-grounding-plug-clamptite-hinged-design-15a-125v-nema-5-15p-orange-thermoplastic.1000806925.html
Any suggestions, ideas, recommendations would be greatly appreciated.
Thanks,
Old 11-07-17, 10:14 AM
Power strip and/or lightrail
Iíve recently done the same thing. I wired a thin power strip under the cabinet and I also installed a light rail moulding to the bottom of the cabinet. Added a little extra room to cover the plug and looks nice
Old 11-07-17, 10:40 AM
P
Received 2,116 Upvotes on 1,895 Posts
Are you able to drill a hole in the bottom of the cabinet? Then mount your receptacle box in the cabinet and run the cord for your LED lights into the cabinet to plug them in.
