Wiring For Motion Light
Old 12-17-17, 12:30 AM
K
Hi,
I am replacing an existing motion light that is no longer working. The house was built in the 1950s, and there is 1 white wire, 1 red wire,(no black) and 1 green wire coming from the junction box. I've got it connected red wire to black wire from light, and white wire to white wire from light, with the green wire grounded. There is no power to the light when turning the switch back on. I've tried 2 different lights, changed light bulbs and checked the circuit breaker. I would appreciate any suggestions on what the issue might be. Do I have it wired correctly, or is it another problem?
Thank you
Old 12-17-17, 04:37 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
HI,it sounds like the new switch needs a neutral , will the light go on if you wirenut the red and white together? What is the model# of the new switch.
Geo
Mod note: Red to white does NOT sound like a correct test step!
Old 12-17-17, 09:26 AM
K
Geo
Hi,
Thank you for the response. I haven't tried wiring the red and white wires together yet. The new light is a Utilitech #0803989.
Old 12-17-17, 11:53 AM
Received 3,410 Upvotes on 3,059 Posts
You have red, white and ground as the house wiring.
The red from house goes to black of the fixture.
White from the house goes to white of the fixture.
Ground to ground.
If the light doesn't work.... you need to confirm 120vac between the white and red supply wires. Remember.... if the light doesn't have a test mode.... it may not come on in the daylight. I couldn't find much info on that light.
Old 12-17-17, 01:56 PM
Geochurchi's Avatar
Pete ,OPD stated only a red ,white ,ground in the box, I am assuming it was a switchleg.
Geo
Old 12-17-17, 03:05 PM
Sorry Geo.... a red, white and ground in a lighting junction box does not suggest a switch loop. Those color wires in a switch box may be a switch loop.
In order to be a switch loop...... there would need to be two cables/four wires at the light junction box. Power in and switch out.
Old 12-18-17, 04:45 AM
Geochurchi's Avatar
Hi Pete, guess I should have read it more closely I thought he was mounting it at the switch location.
Geo
