3 light switch replacement with smart switch
Old 12-19-17, 07:37 PM
W
hi all,
First time post and could use some help determining what to buy and how to install in my particular situation. I have an existing three switch setup where I have one dimmer switch and two regular switches that I want to replace with smart light switches. Can I just buy a single smart switch to replace one existing switch or do I need to get three or do something else? I have attached a few pictures in case that helps.
Old 12-19-17, 08:02 PM
Received 3,892 Upvotes on 3,489 Posts
Welcome to the forums.
Those look like regular single pole switches.
Look on the left side of the switches. If you see two black wires then you should be set. If you see a white wire let us know.
Basically any smart switch should work there. You can replace just one.
Old 12-19-17, 08:25 PM
W
Thank you so much for the quick reply. I will have look and will write back if I see a white wire.
