Casablanca Ceiling Fan - Constant Tone once switched on
Old 12-30-17, 09:00 AM
DPDISXR4Ti's Avatar
Received 2 Upvotes on 2 Posts
I've had a Casablanca fan installed for years, installed new in 2004. I'm not sure of the model#, but it came with a W-33 Inteli-touch Wall Switch, if that helps to narrow down the time-frame. Recently, with nothing having been done, it started to emit a solid tone as soon as I powered it on. I tried swapping out the switch with another W-33 I have from my upstairs fan. For two days it worked correctly, but now it's back to a solid tone as soon as I turn it on. Both the lights and fan operate correctly, but the solid tone continues unabated. The tone pitch does change as the fan speed increases, but instead of momentarily "beeping", it stays on forever. As such, the fan is practically unusable.
Appreciate any input.
Old 12-30-17, 09:42 AM
Received 3,892 Upvotes on 3,489 Posts
Not a very common problem. I believe that sound is controlled on the RMM (processor) board. I don't know how to positively confirm the problem. The RMM conversion kit to replace the RMM board is no treat to install.
casablancafanrepair/InteliTouchCommonRep/ConversionKit.pdf
This is from the Casablanca tech library. It doesn't directly refer to your problem but there is a customer service/tech number that would probably be worth calling.
Casablanca Fan Co. Factory Service Center - Do It Yourself Repair
Old 12-30-17, 08:19 PM
DPDISXR4Ti's Avatar
Thanks Pete. This is the only thing I could find that sounded like someone having a similar problem...
https://www.justanswer.com/electrica...touch-fan.html
But as you can see, the OP never followed up with any sort of resolution. The person who replied had a similar thought as you, that the RMM could be faulty.
I'll drop a message into Casablanca directly and see what I can come up with as a possible solution.
