Connecting LED festoon lights
Old 01-05-18, 08:19 AM
B
Hi
i bought 2 festoon led lights on a cable and I want to connect them together. I have crimper and butt connectors and heat shrink so I can connect them. My question is , is it safe to do so? I am asking since both cable has a little adapters and I need to cut out one of them.
Old 01-07-18, 02:23 PM
Tolyn Ironhand's Avatar
Received 879 Upvotes on 742 Posts
Can you post a picture of the "adapters"?
Old 01-07-18, 03:25 PM
B
Here it is, thank you for your reply🙏
Old 01-07-18, 03:29 PM
B
This photo is better, I guess
Old 01-07-18, 03:55 PM
Received 3,987 Upvotes on 3,579 Posts
You would have to measure the current draw of a single string to see if one adapter could run both.
Then you need to make sure that you have the correct wiring at the end of the first string.
LED light strings uses series and parallel wiring.
I'd say that if there is not a dummy end/ connector on the end of the strings.... they should not be connected together.
