One light not working on 3 branch outside lamp.
Old 01-29-18, 11:47 AM
So, I have an outside Lamppost where as there are 3 60W bulbs inside the glass. One of the bulbs went out and when I went to replace it, the new one one doesn't go on. Any thoughts on how to approach/fix this? Thanks!
Old 01-29-18, 04:40 PM
Received 3,999 Upvotes on 3,589 Posts
It would appear to be a defective socket. Sometimes you can turn the power off to the circuit and bend the center contact up slightly to better contact the bulb.
Old 01-29-18, 05:38 PM
Pete,
Thanks for the reply. The socket was working fine a few weeks ago. I'll try what you said. If that doesn't work, can I replace the socket?
THANKS!
Old 01-29-18, 05:57 PM
Maybe. If it's held in with a screw and not crimped you can replace it.
