Need help changing light fixture
Old 03-06-18, 01:13 PM
I'm changing out a light fixture. The new fixture came with an 'easy connect mounting bracket' that is circular and larger than the existing electrical box which is rectangular. I can connect everything, but the back of the inserts on the mounting bracket don't allow the bracket to sit flush with the wall. What do I need to do here?
Old 03-06-18, 02:04 PM
P
Received 2,009 Upvotes on 1,801 Posts
Some pictures would help us understand the problem you are having. You mentioned "wall". Are you installing a wall sconce?
How does your fixture mount? Does it have two screws spaced several inches apart or is there one big threaded tube in the center?
Old 03-06-18, 02:48 PM
ray2047's Avatar
How to add images. How To Insert Images
If you mean a switch box that uses 6-32 screws replace it with the correct box, an octagon or round box that uses 8-32 fixture screws.
Old 03-06-18, 03:08 PM
Sorry, I thought I posted pictures with the question. I uploaded them, but don't see them anywhere. Let me try again. .
Old 03-06-18, 03:12 PM
Yes, it is a wall sconce. The fixture mounts with two screws a couple inches apart.
Old 03-06-18, 03:51 PM
ray2047's Avatar
A picture of just the box please but it sure looks like it needs replacing with a corect box..
Old 03-06-18, 04:12 PM
Here is the box and the back of the bracket.
Old 03-06-18, 04:49 PM
ray2047's Avatar
Yes a switch box.. Changing it is a good solution.
