Switch Wiring HELP
Old 03-12-18, 08:20 AM
Switch Wiring HELP
I just bought a new house and installed new lighting where a ceiling fan pre-wire was. For the light I just used the black, neutral, and ground to wire the light. There was an extra red wire that I didn't use since that is normally used to control the light on the ceiling fan separately. Now I'm trying to wire the switch for the light. I'm guessing that since the switch is for a ceiling fan pre-wire that there are additional wires. I just want t simple switch to turn the light on and off. I attached the picture of the current wiring. There are 4 wires available for me to use: 2 black wires, 1 red, and 1 ground. The neutral wires have been combined with a wiring nut. What kind of simple switch do I need to purchase? How do I wire the switch (since I am only using the black, neutral, and ground for the light)?
Old 03-12-18, 10:39 AM
Received 3,884 Upvotes on 3,481 Posts
You can use any switch. The two black wires and the ground go on the switch.
The red wire remains capped.
Old 03-14-18, 06:35 PM
Itís still not working
I tried wiring the 2 black wires and ground wire to a single pole switch and itís still not working. I bought a voltage tester and one black wire had voltage and the other no voltage. Should both have voltage?
Old 03-14-18, 07:17 PM
When the switch is turned on..... both wires should be hot.
Old 03-14-18, 07:28 PM
ray2047's Avatar
What's a voltage tester? If you mean a non contact tester your reading is meaningless. You need to use an analog multimeter or test light.
