Can ceiling light socket be replaced?
Old 03-17-18, 02:04 PM
Can this socket be replaced or repaired?
Old 03-17-18, 02:18 PM
Received 3,992 Upvotes on 3,583 Posts
Looks like a plastic socket. It should be replaceable. That metal can where the sockets are should be able to be opened. I can't if there are screws there but there should be.
Old 03-17-18, 02:33 PM
This is what it looks like inside. Looks like all 3 sockets are wired together?
Old 03-17-18, 05:10 PM
Satco 80-1474 socket set. I'd change all three at the same time.
They are also available singly. Many choices on amazon.....
Satco-80-1474
Old 03-20-18, 12:00 PM
Parts ordered. Can I make the connection in the area where the sockets are wired or do I need to pull the fixture and connect in the ceiling?
Old 03-20-18, 04:12 PM
I would cut it as close as possible to the first socket and splice on to it.
Two small wirenuts or crimp caps are all you need.
