I need help identifying what type of ceiling fan I have
Accidentally broke one of the arms on my ceiling fan and need to know the model to be able to replace it. Any help would be appreciated.
Thank you for the reply, maybe you're right, but the decision is not up to me, necessarily. Any idea if it would still be possible to find a replacement arm that matches the one I broke, or if I'll have to replace all of them?
It's pretty hard to identify a fan manufacturer by sight. Most of the fans are made in China and re-branded for different retailers. The chances of finding a single blade are slim. There's a better chance at finding an entire set of five at one of the home improvement centers. Take one of the others off and bring it with you as a template.
For example....
Westinghouse-42-in-White-Bleached-Oak-Indoor-Replacement-Fan-Blades-5-Pack
For example....
I recently had a similar problem with a fan that I bought at a consignment shop ten years ago for $0.25 (yep 25 cents--the price kept reducing the longer the fan remained unsold.) The fan is in a greenhouse and has run continuously for the ten years. One of the arms just broke and fell off. When I was removing another arm to use as a template to find a replacement, I realized that the fan motor had two sets of mounting holes--one for five blades and one for four blades. Not wanting to spend another $15 or so for five replacement mounts, I just remounted the four remaining blades in the appropriate holes. This may be temporary if I come across a replacement but is working fine for now.
