loose fan blade
Old 03-24-18, 01:13 PM
G
Received 11 Upvotes on 10 Posts
loose fan blade
The fan blade in my heater has a tendency to creep forward and hit the front grill. A quick and temporary fix is just to push it back.
The blade is attached to the motor shaft by friction. There is a spring on the fan blade to help with the friction, but apparently not enough.
I guess a permenant fix would be to put some adhesive on it, but I want to be able to remove the fan in case I need to repair other areas. Any suggestions?
Old 03-24-18, 01:36 PM
Received 3,982 Upvotes on 3,574 Posts
I'd use a little blue LocTite on it.
