Exhaust fan wiring
Old 04-10-18, 05:36 PM
W
Exhaust fan wiring
I need some advice.I have installed a new exhaust fan in bathroom and I can't see to get it wired right.I have 12/2 wire in attic which is where i will tie 4 wires from double pole receptable that I need to run from switch to attic.I also have wires from exhaust fan blue & white & a black and white.One for fan and one for light.Pleas tell me how to get this wired right so it will work and not trip breaker.I feel comfortable doing this but just need some help.One more thing I want to wire the fan and light together so they will both come at same time.Thanks
Old 04-10-18, 05:48 PM
Received 3,886 Upvotes on 3,483 Posts
You have a 12-2 cable feed in the attic.
4 wires..... two 12-2 cables to the switch ?
Double pole receptacle ?
Need some clarification here.
Old 04-10-18, 07:58 PM
W
Exhaust
OK I was wrong it is 14/3 3 wires including ground.3 wires from each side of switch and only 3 wires that I want to tie into plus the 4 wires from exhaust that I want to tie together so when I turn switch on light & exhaust comes on together.Thanks for your help
Old 04-10-18, 08:03 PM
Ok.... so there is a 14/3 w/gr from the switches to the fan location.
Are there two switches there and you only want to use one or do you want the fan and light to be switched separately ?
Old 04-10-18, 08:55 PM
W
Exhaust fan
There are 2 switches and one of these will operate lighting over sink which I have hooked up and working.This wiring was there before installing exhaust.I just replaced single pole switch with a double pole switch.I want the exhaust fan and light on exhaust fan to operate as one.
Old 04-11-18, 02:49 AM
W
Exhaust fan
Hopefully I can make this a little more understanding. One wire was already installed on a single pole switch for lights over sink.I replaced single pole switch with a double pole switch.I connected existing wire to new switch so bathroom lights over sink would work.These lights are working.I then ran another 14/2 wire from switch to attic. Now I need to connect new wire from switch to another 14/2 wire in attic for power.How do I splice wire from switch to other wire in attic for power.I also have the blue and white and black and white from exhaust fan which is for light and fan that I want to wire together so when I flip switch light and fan will come on together.I appreciate any help.All wires are 14/2 with hot,neutral,ground.I really appreciate your help.
Old 04-11-18, 11:41 AM
W
Exhaust fan
Can you please help me figure this out.
Old 04-11-18, 12:31 PM
ray2047's Avatar
Do you mean a duplex switch, two switches on one yolk?
Old 04-11-18, 12:33 PM
W
Fan
Yes that is exactly the switch I installed.
Old 04-11-18, 01:49 PM
ray2047's Avatar
The tab is not removed.
Power black goes to the tab side.
Lavatory light goes to one of the screws on the side opposite the tab side.
Fan goes to the other screw on the side oppisite the tab side.
Assumes power comes into the switch. All neutrals connected together. Below one diagram for 3-conductor cable and one for two 2-conductor cables.
Old 04-12-18, 12:33 PM
W
Exhaust fan
OK for some reason I still can not get exhaust fan and exhaust light to work correctly .The laboratory light works fine.The bottom switch is what I want the exhaust fan & light to work from.I have wire from bottom switch ran up to exhaust fan and light to hook up.Wires coming from fan are blue & white for light and black and white for fan.please tell me how the wires from exhaust fan and exhaust light hook up to live wire that I cut in ceiling which is the power to labtory light.So I have 2 wires from exhaust fan for light and fan,2wires from switch, ran up to attic.What wires go together and then wired back to power source.Keep in mind I only have black and white with ground on wires coming from switch and all wires in attic except the blue white coming from exhaust and black white coming from exhaust.I just couldn't seem to figure out last diagram.Would it be better to try and find another power source for exhaust fan and light and come from it to switch.
Old 04-12-18, 01:04 PM
Having a hard time understanding. We can only offer help when we know everything that is there. This is what I think you have.
You have two existing wires in the box that were on a single switch. Put them on one of the duplex switches. Connect only the black and red from the three wire to the other duplex switch. Break the tab off of the hot side.
If this doesn't look like what you have..... give us a full description of the wiring at the switch.
Old 04-12-18, 01:49 PM
ray2047's Avatar
Blue and black to switch power in hot wire. White to white.
Do you have a power in cable at the switch?
Old 04-12-18, 05:15 PM
W
Exhaust fan
Hey the last explanation and I finally got it.Everything works as it supposed to and I just want you to know how much I appreciate it.I could not have did this without your help. Thank you very much.
Old 04-12-18, 06:08 PM
ray2047's Avatar
Glad we could help. Thanks for letting us know the outcome.
