How do I wire this light fixture?
Old 04-14-18, 06:36 AM
It's a yard blaster on my porch.
The fixture itself has 2 whites and 1 red.
The socket has 1 white and 1 black
The switch has two blacks ..?
The lamp is a direct wire LED so would I splice the two whites at the fixture to the white at the socket and the red to the black?
Old 04-14-18, 11:26 AM
Received 3,886 Upvotes on 3,483 Posts
From the switch you are sending up an NM cable with black, white and ground in it. It looks like the NM cable is outside and connects under the fixture.
Almost impossible to tell what's happening with the picture.
Is that the old fixture with the guts removed ?
How does the new fixture attach to that ?
You will probably have to open the wiring cover where the red and white wires go in to access the splices
Type NM-b cable is not supposed to be outside in sunlight and wet conditions.
