How to check if electrical box is good to mount ceiling fan ?
Old 05-20-18, 01:11 PM
R
i bought a house and would like to replace ceiling light with ceiling fan in one of the rooms. I would I know if he electrical box is good to put ceiling fan on ? Is there any way to visually tell if fan can be mounted ?
Old 05-20-18, 01:30 PM
Received 3,897 Upvotes on 3,494 Posts
Welcome to the forums.
We know by looking at them. They usually use a larger size mounting screws.
If you post a picture we can comment on it..... How-to-insert-pictures
Old 05-21-18, 06:32 PM
R
Hi, attached please find the pic.
Last edited by PJmax; 05-21-18 at 07:05 PM. Reason: added enlarged/enhanced picture
Old 05-21-18, 07:08 PM
I can see it's a standard 4" round electrical box for romex and missing the two romex clamps.
It is not a fan rated box.
I can't tell what type box it is. It looks like a nail-on to the side of a joist. Fairly easy to change for a different box.
Very important...... since you'll need to change that box out. Label the four cables like A, B, C and D and take another picture. This way you'll get the connections right.
Old 05-25-18, 08:10 PM
Hi,
I agree with Pete, this is not a fan rated box. You would need to replace the box with a ceiling fan electrical box. Double check the weight of the fan. If it is less than 35lbs, I recommend using something like the following link from Lowes. It's less than $7, and will do the trick.
https://www.lowes.com/pd/CARLON-1-Ga...al-Box/3128115
Good Luck!
Mike
Old 05-25-18, 08:28 PM
@Mabrus.... although the box you linked to would work for a fan.... it would require the sheetrock to be cut in order to hammer the nails in.
This type of box can be installed without cutting the sheetrock.
Madison-Electric-Products-Fixture-Support-50-lbs-Ceiling-Fan-Support
