Re-connection of a 240volt safety electrical pole lamp.
Old 05-26-18, 09:12 AM
U
This is a 240v westinghouse pole lamp. It have a transformer inside. Only two black cables . I don't see any third cable for neutral mother ground. How it is suppose to be connected to the utility electrical pole.. Any help will be appreciated. Thank you.
Old 05-26-18, 09:19 AM
Received 3,886 Upvotes on 3,483 Posts
Welcome to the forums.
The utilities don't ground their lights as it's not needed since no one can touch them.
You can add a ground wire to one of the mounting bolts if you want.
You will only have two wires for a 240vac connection. No neutral required.
I'm assuming this is a private pole and not one owned by the utilities.
