Closet lighting?
Old 05-27-18, 06:57 AM
maarkr's Avatar
Received 18 Upvotes on 16 Posts
Closet lighting?
OK, in this house there's switched porcelain lights installed abt 6" from the front of the closet. This is a bedroom closet with sliding doors, abt 2'x6'.
Can i just replace the light w a receptacle and plug in one of those 5w led motion/light sensor lights like I use for nightlights?
Would you move the box to the center of the closet?
Old 05-27-18, 09:35 AM
Tolyn Ironhand's Avatar
Received 675 Upvotes on 573 Posts
Yes, you could put a motion sensor. I would not relocate the lights as you need to stay 12" away from the closet shelf. The bulb should also be enclosed, not a bare bulb.
Old 05-27-18, 11:16 AM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
If the sensor type bulbs are enclosed in a globe the sensing may not work. Another alternative is to use a motion sensor switch.
Old 05-27-18, 03:54 PM
An LED bulb would be a solution as the LEDs are already enclosed.
Old 05-28-18, 05:13 PM
maarkr's Avatar
sorry, i should have put this link in... I've used something similar to this for years in my bathrooms and near exits.
led motion nightlight
Old 05-29-18, 05:18 PM
That would be fine. There is no restriction for installing receptacles in closets. They may be required to be AFCI and tamper resistant.
