Change/Fix Ceiling Light
Old 06-28-18, 02:12 PM
C
Hi All,
We have a few ceiling lights like the one in the picture that are out. I was hoping to get some guidance on how to go about changing out the bulbs. I am able to push the bulbs up and the fixtures around the bulb rotate/can change angle, but I don't want to damage/break anything in the process of trying to remove the bulb. Any help would be much appreciated. Thank you!
Old 06-28-18, 02:30 PM
pcboss's Avatar
Received 192 Upvotes on 168 Posts
You may need to break the paint seal and pull the trim down to access the bulb.
Old 07-01-18, 01:16 PM
C
Crikey, a bit more involved than I had hoped. Thank you for the help and advice!
Old 07-03-18, 06:37 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Really not that bad, just take a utility knife an score a line around the trim, what is the Dia. of that trim? it looks like a low voltage Halogen bulb.
Geo
Old 07-03-18, 12:24 PM
W
That installation looks horribly sloppy! As mentioned, cut what appears to be caulk and remove the trim. Remember to replace with a LED bulb!!!!!!
Old 07-05-18, 10:34 AM
C
Thanks Geo and Wick, I appreciate the help.
