Problem with fan motor wire diagram
Old 08-14-18, 11:23 AM
D
Hello all,
I was hoping someone here would know the answer to this. I have a motor I need to wire for a large drum fan. It is a 115v fan with 2 speeds. There are six connectors which are: L1 L2 Ground Common Hi Lo. What should I do? There is continuity between L2 and Common and also between Hi and Lo.
<img src="https://lh3.googleusercontent.com/ggHu1pro8qQPx-0c66K19mJ9jxYMOhnv-OiHyu9CFAA6nu7dumQBVw58zwBcO1rdiTMH1VjGU0cuauLZx2ViDpD4OYUzov1F_EFy-q0HbE1sy7CZwe7kFGOEfyPBqdiJcct6G2IYvfzDllixlZej7p2C0nURT8hmOxE3eSKGRHFNQ2pQlb4H3JfpoA2dRjp0hVx2SEGALjv6Y8sh6AGPIfXkuvWfHAmSfXTfR_U2bIZuI_YF5vtEYKM7r0y7tUVwYB19rnpOCr549uRJep1bhWnX5OLUq09P1tj2fIY-YC_koUoyxwpYCoXVvRNarUHHoTf1SCbxXofKDTZUQsCmWcQbyHbVJN67nBareP-cDrJNd6Ee-u475LRG5qUIICrb3xg9DvUDR1Y6ZIgimpbjF6qaet4hZ0AqqIFtw5dAgtrkClP-Ju78KTaOFI9Usm1VUxc-0O-KvGdw_zwB3ZegtTMFFJLsFBO0e27PdevscHnCt0yRfVPnoIDpC8IRZLyoOHvCD7GNsyJ4lXEOefgZkDSnKywpi90jPQAh3FYJ-g_blQ5CIzGgxfbPbGc5FhyBLKWygV5dlancJOFI9ekgzFbFjkbIui4tnhcxzPgZpCjeE7nuXNqB1UBVR1KpaEpq8jAtzy7lXbC9VBWAnh6sPzsG1Q7RPLY=w996-h747-no" width="996" height="747"/>
Thanks!
Devin
Old 08-14-18, 11:53 AM
Received 3,424 Upvotes on 3,070 Posts
Welcome to the forums.
It looks like a motor specifically designed for fan use. It's 120vAC only and two speed.
You connect your power cord to L1, L2 and ground.
You can use a switch to select hi or low speeds. If you don't want to use a switch to select speeds.... put a jumper from COM to Hi for high speed or from COM to LO for low speed.
