Can I cut incandescent rope light...and use end cap ?
This is American Lighting 042 series incandescent rope light on outdoor deck railing. About 10 feet not needed. I can always direct rope under the deck so it is hidden...but I did not see any "cut marks" on a 5' piece I inspected. Mfr. says don't cut.
So.....hide or cut and cap ?
Thank you
Thank you
Typically 120vAC incandescent rope lighting cannot be cut because all the bulbs are in a series string and are like Christmas lights where you remove one bulb and the string is dead.
You could post a close up pic of a piece of the tubing for further review.
It appears that it can not be but , is it a full 10’ piece or is it coupled together with the approved connectors? There are approved end caps for termination.
Geo
Geo
It is 50' and a 30' coupled. Guess I could get a 20' and find a use for the 30'. Thanks for your replies.
I ended up using the entire string....and used black pipe insulation to cover up the last 10+ feet.
