ballast or bulbs (or neither?)
Have a fluorescent setup on kitchen ceiling. Two lamps, with two fluorescent bulbs each.
Lights are not coming on until the 3rd or 4th time I flip the switch off. Once they come on, there is little flickering (flickering is normally what I think of as ballast-related). It seems to be straight from dark to light once it comes on on that 4th try. Is this ballast, bulb problem, or something else?
It's hard to say what is causing the flickering and poor starting. The usual first step is to replace the bulbs especially if the ends are darkened. But I would not bother. I'd just convert the fixture to LED. That way you don't care what the problem is as you'll be getting rid of both the ballast and fluorescent bulbs.
Very simple, I just replaced all my bulbs in the garage, cut 6 wires to remove the ballast then reconnect the line wires to the tombstones, takes about 15 minutes per fixture!
I got super high output for the garage, more than you would put in a house but it;s like daylight out there now!
