trying to exchange dead halogen pot to new led
Old 10-31-18, 08:07 AM
E
My existing halogen pot (in ceiling in insulated box behinf drywall) is not working and i want to replace with an LED pot. I see 2 white wires to the socket of the Halogen, The LED has a black box with three wires,black,white,and yellow/green with a plastic connector on the end of each wire. Can i connect the two white wires one each to the black and white of the LED, and what to do with the yellow/green (i guess this is ground). I have pics but can't see how to attach.
Old 10-31-18, 09:50 AM
P
Received 2,186 Upvotes on 1,956 Posts
What voltage is your old halogen? Some are 120 VAC while others have a transformer so the wires to the bulb are 12 volts.
Old 10-31-18, 04:42 PM
Received 3,992 Upvotes on 3,583 Posts
Sometimes you need to pull down the can/insert to make the conversion.
We can help you better after we see a picture or two....... How-to-insert-pictures
Old 10-31-18, 06:25 PM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
At least in the US there are screw in LED kits. Remove the halogen bulb and screw in the LED. Push the trim up into the housing.
