Replacing Bath Fan Switch with Timer Switch
Old 11-30-18, 11:08 AM
P
Hello, I have two questions about this project:
Which neutral pigtail bundle should I tie the white wire from my new timer switch to? My outlet box has two sets of white neutral pigtails. One has two wire, one has three.
Also, please confirm; I will tie the hot black from the new switch to the black pigtail bundle. And I will tie the red load wire from the new timer switch to the black wire from cable 3 in my diagram.
Thanks for your help.
Peter
Old 11-30-18, 01:45 PM
ray2047's Avatar
White of dimmer goes to the bundle that contains the white from the cable that supplies power to the switch.
Old 11-30-18, 05:48 PM
P
Thank you Ray. So that is one of my questions... the cable that supplies power to the switch is cable 2, it has two neutrals going to two separate bundles. Maybe it doesn't matter which bundle the new switch white goes to?
Old 11-30-18, 06:19 PM
ray2047's Avatar
A cable should have only one white. Are you sure both whites are from the same cable?
Old 11-30-18, 11:21 PM
Received 3,880 Upvotes on 3,477 Posts
Your diagram is showing three cables in that box. Your picture shows five cables there.
Old 12-01-18, 09:08 AM
P
Ray, Pete...wow, thank you. I feel pretty stupid. Yes I can see now that there are actually 5 cables in there, cables 2/3 and 4/5 are just really close. Shows you how an inexperience eye can make a mess of something obvious to pros. I'll redo my diagram and have another think about it (I feel this should be within my grasp and dislike not understanding my house) but suspect I'll be calling someone on Monday.
Thank you again.
Old 12-01-18, 09:25 AM
ray2047's Avatar
Please do not include the grounds in your next diagram. They make it much harder to read. We will just assume the grounds.
Old 12-01-18, 11:59 AM
P
New Wiring Diagram
I took another look with your help and did a new diagram.
Old 12-03-18, 11:27 AM
P
I have just finished the install and the switch is working perfectly. Thank you guys for your insight and generosity with your time and expertise. This site is a great resource.
Peter
