Help wiring a Leviton IPS02 motion sensor switch
Old 12-01-18, 05:29 PM
D
Hello, new to here, hope to get some help.
I take away the old switch and try to install a motion sensor switch.
But once I switch on the power, the sensor on the switch is blinking, but the light won’t turn on, even I press the button.
Here is the wire, please help and let me know which wire should go to which screw on the switch.
Old 12-01-18, 07:52 PM
Received 3,983 Upvotes on 3,575 Posts
Welcome to the forums.
I labeled your picture. Line to black..... load to red.
The sensor must be grounded to work properly. Check the box for grounding.
Installation instructions
Old 12-01-18, 10:17 PM
D
So the neutral just stay the same?
Old 12-01-18, 10:22 PM
Yes. That sensor doesn't require a neutral.
If you don't have ground in/at that box..... you'll need to get a sensor that does use the neutral.
Old 12-01-18, 10:32 PM
D
As you see the 1st photo, is that 2ground wire hook up to the screw?
Old 12-01-18, 10:44 PM
It's hard to see IN the box. It looks there is a ground wire. It still needs to be tested.
The two white wire splice is not ground.
That sensor has to be grounded to work correctly.
Old 12-01-18, 10:56 PM
D
Let me try to take another photo tomorrow, thank you
