Wall light with switch built in it won't shut off
Old 12-15-18, 10:08 AM
E
Smile Wall light with switch built in it won't shut off
<img src="https://encrypted-tbn2.gstatic.com/shopping?q=tbn:ANd9GcQPJAsKOR3yLBE6bxWrbk5dr7WAFDhl-J4t0VOdkfmYfAvU5KwgnnbHI0gw-sZjKx65ImbbsJ6WxF2dD3DBAHbt1KUbV5uQAwvYh1yoSsJFlKGKKR-DurmY&usqp=CAE" width="450" height="450"/>
He-e-elp!!!
Old 12-15-18, 10:58 AM
Received 27 Upvotes on 21 Posts
Sounds like a faulty switch. Just unscrew or remove the bulb until you can get another.
Old 12-15-18, 11:21 AM
Received 3,992 Upvotes on 3,583 Posts
Welcome to the forums.
What kind of light..... a wall sconce ?
Old 12-15-18, 11:55 AM
Received 517 Upvotes on 422 Posts
Could be miswired. If the power feed was put to the socket instead of the switch it would bypass the switch.
Old 12-17-18, 02:48 AM
E
Thanks! It would make it almost be similar to a wall socket, right?
Old 12-17-18, 05:34 AM
ray2047's Avatar
More likely the switch on the bottom if it previously worked. Remove nut from bottom to remove socket. New socket example: https://www.homedepot.com/p/Leviton-...-051/100356978
You may need to remove the fixture to get enough slack in the wires to pull the lamp socket out. Be sure to turn breaker off first.
