15a max lamp on a 20a circuit
Old 12-22-18, 01:11 PM
X
hello- the thread title pretty much says it all. Installing 2 lamp fixtures on a 20 amp circuit when I noticed the lamp says 15 amp max. These 2 lamps are the only thing on the circuit. If I continue to install them am I creating an unsafe situation? Do I have any options that let me use the lamps?
Old 12-22-18, 01:13 PM
Received 3,422 Upvotes on 3,068 Posts
I've never seen a lamp that has a maximum amperage rating on it. Can you post a link to it for us ?
If no link.... maybe a picture.... How-to-insert-pictures
Typically it's understood that no lamp could be connected to a circuit larger than 20A.
Old 12-22-18, 01:32 PM
X
Ok I think I attached it correctly
Now that I look at it I wonder if the amp limit refers to the outlet on it?
Old 12-22-18, 01:56 PM
F
MAX rating
Yes, I believe that label is for the outlet so that you do not try to light all the Christmas decorations on that single outlet.
The outlet contacts and internal wiring likely can not handle heavy current.
Cheers!
Old 12-22-18, 02:01 PM
P
Received 1,768 Upvotes on 1,581 Posts
Yes, that is the capacity of the outlet not the circuit feeding the fixture.
Old 12-22-18, 07:24 PM
X
Thanks for the help everybody
Old 12-23-18, 12:25 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
Where are these fixtures located? If in bathrooms the outlet must either be GFCI protected or disconnected from power.
