track lighting flashing
Old 01-21-19, 07:41 AM
I installed new track lighting and a new dimmer switch. it is flashing sometimes. any idea what is wrong?
thanks
Old 01-21-19, 08:06 AM
Received 516 Upvotes on 421 Posts
type light? LED? CFL? Halogen?
Type of dimmer? LED/CFL compatible?
Flashing when on or when off?
Old 01-21-19, 04:14 PM
Track lighting
the lights are led. The dimmer is led cfl compatible. They flash when on.
Old 01-21-19, 05:00 PM
ray2047's Avatar
Compatible with LED is more magic than science. First try with non dimmer switch. If no flashing try different brand of dimmer.
Old 01-21-19, 06:35 PM
Received 3,977 Upvotes on 3,569 Posts
One problem with LED bulbs and dimmers is that the bulbs don't supply enough of a load for the dimmer to stabilize. It's possible to hit or miss one that works better.
Better dimmers will be more stable with less flickering and dimming issues. I use the Lutron Maestro MACL for the most reliable dimming.
Old 01-22-19, 11:13 AM
Two sets of lights
i have two sets of 4 track lights on one dimmer would that make a difference?
Old 01-22-19, 02:31 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Two tracks should not be an issue.
