Ballast bypass in the kitchen: now chandler isn't working
Old 02-02-19, 06:25 PM
A
Exclamation Ballast bypass in the kitchen: now chandler isn't working
I took the ballast out of a tube light fixture and replaced it with LEDs and the chandler next to it isn't working.
A continuation from.... need-help-ballast-bypass-fluorescent-led
Old 02-02-19, 07:17 PM
ray2047's Avatar
Sounds like you failed to connect the wires to the chandelier that were connected to the power in in the fluorescent light. Tell us about the wires coming into the fluorescent.
Old 02-02-19, 09:41 PM
Received 3,897 Upvotes on 3,494 Posts
There are only two cables there. Does one switch control both lights ?
Old 02-03-19, 06:27 AM
Received 513 Upvotes on 418 Posts
Might just be a coincidence. Did you check the lamp in the other fixture.
Old 02-03-19, 03:36 PM
A
Not the same light fixture
I Changed out a light fixture in the kitchen from fluorescent to LED that only had one black, white and ground wire coming out and connected each end of the socket to each wire, and when I left, my friend said the chandaler next to it wasn't working anymore. They aren't on the same switch panel.
Old 02-03-19, 03:48 PM
Unrelated stuff happens sometimes.
