3 way switch to one way switch help
Old 02-07-19, 06:59 PM
D
Hello i was wondering how do i connect a 3 way switch to a single pole switch because the way i have it connected the single light only turn on when the switch for the 3 way is on i have the neutrals all tied together and my hot for single and 3 way switch tied together
Old 02-07-19, 07:38 PM
ray2047's Avatar
You don't use a 1-way switch with a 3-way.
Old 02-07-19, 07:39 PM
Received 501 Upvotes on 411 Posts
You can't with that configuration. You do not have a constant hot. You only have the switched hot of the three way.
Your diagram is wrong also. There should be one black on each screw of light switch not both on one screw.
Old 02-07-19, 08:46 PM
D
yes but is there any way to connect a 1 light single pole switch off a 3 way switch or its just not possible? thanks
Old 02-07-19, 09:23 PM
In the drawing yo have there is no way. You do not have an unswitched hot. You could probably do it from the other three way on this circuit.
Old 02-07-19, 10:54 PM
D
ok thank you for the info
