24V LED 5050 wiring Layout and Wire Gauge Question
Received 0 Votes
Any thoughts on this electrical layout?
The blue numbers/lines are showing lengths of wiring I'll use.
The LEDS are strips and they are hi density 24v 5050 LED (RGBW) lights which are 600LED/Meter. They draw 6.4Watts/FT.
The total amperage draw for lights would equal 3.73 AMP. I want to wire the power supply in the middle of the circuit as shown and tee off from there.
If this looks ok I also wondered about wire gauge requirements. The heaviest gauge 5-pin wire I've found is 18 gauge. Since these are parallel circuits do my wiring gauge requirements lessen as shown in the bottom picture?
Any help would be appreciated. Thanks
Does each strip need a 5 wire cable to it ?
If yes..... make each strip its own 18-5 run back to the supply.
Received 0 Votes
I need 5-pin.
If I run each strip all the way back to the PS there will be less amperage on each circuit correct?
I ask because I can buy either 22, 20, or 18 gauge. If I'm running each on their won then 20 gauge should be heavy enough?
Each circuit amperage stays the same but the load is smaller on each wire if they are all separate.
#20 would be fine there too.
