Incorrect Wiring
Old 03-20-19, 04:14 PM
H
Exclamation Incorrect Wiring
Hey Everyone,
I just got a new GE smart switch that I installed. (seen on right of the picture)
After getting everything wired up, I went to check the voltage and found the following:
When I check the current on the the screw from the breaker everything is fine, but when I check the current on the one to the light, everything when up in sparks and breaker box killed the lights (a good thing)
Any thoughts on what I did wrong?
Thanks!
Name:  Light Switch.jpg
Old 03-20-19, 04:21 PM
Received 3,975 Upvotes on 3,568 Posts
Welcome to the forums.
Your probe probably shorted from the screw terminal to the switch yoke which is grounded.
What is the actual problem ? Why were you checking voltages on the other switch ?
Old 03-21-19, 03:17 AM
H
Thanks for the prompt response!
I was told that it was best practice to recheck the voltage after I get everything hooked back up to make sure I didn't accidentally knock anything around.
I'm guessing that is not true.
Old 03-21-19, 08:33 PM
Really no need to check the voltage. Just turn the switch on. Either the light works..... or it doesn't.
Old 03-23-19, 08:09 AM
H
Sounds good! Thanks PJmax!
