Ceiling Fan Wiring Help
Old 04-22-19, 07:22 PM
Lightbulb Ceiling Fan Wiring Help
Hello Guys,
Need some help trying to wire this fan and fan light to turn off and on at two locations. Attached is a digram of the wires that are in the walls. Can it be done without adding any more wires? Will the light switch on the west wall need its own power source or will I be able to pig tail off the 3 wire coming into the 2 gang box? What type of switches will I need, single pole, 3 way, or 4 way?
File Type: pdf
Old 04-22-19, 08:00 PM
Received 477 Upvotes on 393 Posts
You can't do it. You need another three wire for the fan three way. You need a power feed for the light in the two gang box.
