Moving switch to other side of stud / rough cost estimate?
Old 05-21-19, 03:57 PM
Received 4 Upvotes on 4 Posts
Hi-
I have an electrician coming out next week to give us a quote on moving a switch. We would like to move it out from under the cabinet to the right somewhere so we can access it. The previous owners extended the cabinets but didn't move the light switches. I believe there are studs where I put the yellow lines.
I know this may be a difficult question to answer but does anyone have an idea of a price range to get this done in the Seattle area? They said they will quote and do it right then if we accept. I just want to get this done so I am likely to just say yes but I also dont want to be overcharged.
I guess I could try this myself but I dont have any experience pulling stuff through studs and its probably not worth the hassle.
Any thoughts would be appreciated.
Thanks!
Old 05-21-19, 04:07 PM
Received 1,262 Upvotes on 1,203 Posts
Between 10 and a thousand dollars. Best bet is to get three local estimates so you can compare; trying to estimate remotely like this is pretty much pointless.
Old 05-21-19, 04:10 PM
Thank you. $10 would be fantastic!
Old 05-21-19, 04:33 PM
Received 3,880 Upvotes on 3,477 Posts
One switch could possibly an easy DIY job. Three switches is going to be more involved.
The job will be basic and easy if the three gang box can remain there as a covered splice box.
If the wires all need to be re-routed.... you'll be looking at big bucks.
Old 05-21-19, 04:37 PM
Thank you. We have a piece of the wood paneling so I was thinking that everything would be spliced together inside the current gang then routed to the right. Then we push the cut to size piece of wood panel in the bottom there and everything is covered up. Is that the basic job you were speaking of? thanks!
Old 05-21-19, 06:12 PM
Received 513 Upvotes on 418 Posts
You can't cover it. It needs to remain accessible.
Old 05-22-19, 04:02 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
You could put your wood panel there but cut hole for box and than put a blank cover over box. I know this somewhat defeats a clean panel there but easiest and cheapest
Old 05-22-19, 04:49 AM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
As far as price? If you feel comfortable with his quote go for it. I've learned over the years to go with the quote that I feel is fair and I can afford (all things being equal). Although I try to get multiple quotes on projects, getting the best price (not cheapest) can be futile. Somebody will always tell me they could've gotten it cheaper.
Old 05-22-19, 05:59 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi, what is above the cabinet????????
Geo
Old 05-22-19, 08:07 AM
Thanks everyone. Whatís the reasoning behind having access? Is it a fire thing or so that someone always knows that itís there?
Old 05-22-19, 08:59 AM
ray2047's Avatar
Mostly because if you lose electric due to a connection you can find it.
