Exposed Romex across attic ceiling studs?
Old 05-31-19, 07:37 PM
A
I am wanting to run Romex 12/2 type NM-B wiring from a bathroom 3-function switch up through a wall and then across to a ceiling fan/heater/light. The attic above is really just a crawl space with exposed studs and with of course the drywall below for the bathroom ceiling. There's also blown insulation up there. My question is it allowable to have the exposed Romex wiring running between the ceiling studs (with no conduit)?
Old 05-31-19, 07:46 PM
Received 518 Upvotes on 423 Posts
Yes. It should be stapled to side of one of the ceiling joists every 4 feet.
AndyRooney voted this post useful.
Old 05-31-19, 08:01 PM
Received 4,046 Upvotes on 3,630 Posts
Across ceiling joists.... as over the top....... or along the side of ceiling joists ?
Old 05-31-19, 08:05 PM
Received 1,273 Upvotes on 1,213 Posts
You've asked two entirely different questions between the title and the last sentence in your post. Could you clarify what you're actually doing?
Old 06-01-19, 06:09 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, is the ceiling strapped? cable could be fished between ceiling and joists.
Geo
Old 06-01-19, 10:11 PM
A
Thanks joed.
Not sure what "strapped" is.
Old 06-01-19, 10:25 PM
ray2047's Avatar
Strapped is boards spaced a foot or so apart between the Sheetrock and joists,
Old 06-02-19, 10:46 PM
A
Can Romex run over top of ceiling joists or are they supposed to run through drilled holes?
Old 06-03-19, 05:48 AM
It can run over top if more than 6 feet from the access hole in the ceiling or if protected by a running board.
