Metal vs pvc for running line on outside of house
Old 06-04-19, 10:15 AM
D
Need to run outdoor 20amp receptacle outlet, switch and a LED light on outside of house. Obviously sched 40 pvc much cheaper. Any opinions on way to go?
Thanks
Old 06-04-19, 03:10 PM
Received 513 Upvotes on 418 Posts
PVC. You won't need to worry about it rusting out.
Old 06-04-19, 05:42 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi, how long is the run? If the PVC is exposed to a lot of sun light it will need to clipped really well or it may sag.
Geo
Old 06-04-19, 05:44 PM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
Is PVC rated for ultra violet rays from the sun if exposed?
Old 06-04-19, 06:19 PM
R
Received 67 Upvotes on 52 Posts
I would use pvc and paint it to solve UV issues.
Old 06-04-19, 07:16 PM
Received 3,892 Upvotes on 3,489 Posts
PVC is sunlight resistant and can be installed on the house. One problem with PVC over conduit is that the PVC can be hard to run straight and keep straight. The bulk of my outdoor lighting jobs are done with 1/2" EMT.
Old 06-06-19, 06:05 PM
B
Smile No romex in PVC
Do not put romex in your PVC, and I would use grey. So that someone else can see that there is 120 Volt inside. Check your codes, some state do not let a homeowner do the wiring. Are you going underground with this?
Old 06-06-19, 06:24 PM
Welcome to the forums Brad.
This looks to be strictly an "on house" installation. It is ok to use UF in outdoor conduit but not NM-b (romex). One reason that cable is not usually used in conduit is that it's too hard to pull. The cable does not go around bends well.
Old 06-06-19, 06:45 PM
All conduit outside is considered a wet location. NM-B is not rated for wet. You need to use wet rated cable like UF or THWN wet rated individual conductors.
