Hardwire Outdoor String Lights
Is it possible to hardwire these lights into the wall light unit ?
You said "wall unit" but then show a standard three prong plug. Do you wish to bypass the plug and wall socket and hard wire those lights into a junction box?
Unfortunately we cannot recommend you cut the plug off and hard wire those festoon lights.
I've seen it done but it is not to code so we can't endorse it.
You would be better removing the wall light to see if you can add or replace what is there with a box and receptacle. Then you could plugs the light string in.
I like the idea of adding a receptacle instead of or next to the fixture. Add a GFCI receptacle to protect the light string (and people), and you'll be all set.
