Wifi Light Switch
Wifi Light Switch
I am installing a Wifi Light Switch. I'm more of an IT person but I should know and would like to know how to do this as well. Below are the two images. I can take more.
In the picture with connected wires, there is a greenish colored wire in the back going into where the RIGHT beige colored wire is coming from. Any help would be greatly appreciated.. I also have the push in wire connectors.
Thanks
Thanks
Last edited by PJmax; 06-06-19 at 06:56 PM. Reason: Color balanced, cropped, resized image.
That is two black wires. One of them is covered in paint.
One of the black is the LINE. The other is the LOAD. No way tell from picture which is which.
The two white in the yellow wire nut are the neutral.
Any green or bare wires not seen are the ground.
That cable looks like extension cord. That should not be inside a wall.
does this look right?
Does this look like the right setup? I'm hesitant to try and turn the power back on. what is the worst that can happen? can somebody please help. Any advice. Thank you!
