Replacing occupancy sensor to 3 way switch
Old 06-15-19, 01:57 PM
Hi.
I have a motion sensor installed in my laundry room that I don't like. I just put a new fixture up and thought I'd replace the occupancy sensor with a regular 3-pole rocker switch. It didn't work. I thought that the light was the problem because I've replaced many switches in the past. Light checked out and worked fine when I reinstalled the occupancy sensor. Can anyone help me out with the wiring of the rocker switch??
I attached a couple of pics to help. One is the current wiring to the occupancy sensor, the other is the replacement I want to use.
Thank you for any help with this.
Old 06-15-19, 02:46 PM
Received 3,881 Upvotes on 3,478 Posts
Welcome to the forums.
I labeled your pictures. I know the red wire is definitely a T (traveler) and I'm fairly sure I have the other two black wires labeled correctly. If it doesn't work correctly from both switches.... reverse the two black wires.
Old 06-15-19, 04:23 PM
Received 513 Upvotes on 418 Posts
The black wire coming from the cable with the red wire should be the traveller.
You also need to verify the wiring at the other switch. It may have been changed to work with the sensor.
Old 06-15-19, 08:04 PM
Thank you guys for the quick reply.
With the labeling, is there a particular side the red one has to go on to the new switch? Or, are the traveler wires interchangeable?
Thanks again to you both, I will mess with it again tonight and update you.
Old 06-15-19, 08:16 PM
The travelers are interchangeable.
