Question about Halo Recessed Housings With Push In Connectors
Old 07-07-19, 09:27 AM
C
I bought new Halo recessed housings, and they have push in connectors built into the junction box. I've never used them with any of the work that I've done. I was wondering if I should use these connectors, or if it would be preferable to cut the wires and use wire nuts. I always like my work to look professional, so I wanted to double check. I'm curious what electricians generally do when they see these in the box.
Old 07-07-19, 04:35 PM
F
I've put in a few and never had a problem.
Old 07-07-19, 07:58 PM
Received 3,993 Upvotes on 3,584 Posts
I know many electricians that use them and have had no problems.
Personally I still use the wire nut method. I'm not comfortable with push-in connections.
Old 07-08-19, 12:23 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
When I replaced all the ceiling fixtures with cans I used them, and reluctantly gave them a try, it made them easy to install and nothing failed!
I had more issues with the circle template for the hole, it was way too big!
