Kitchen light - electrical box
Received 0 Votes
Hi,
I am doing some re-modeling of my kitchen. Above the window the last owners had a rectangular electrical box with live terminated wires as you can see in the attached. I assume this was for a light although there is no light switch.
My plan is to put a light back here rather than leave this ugly box. It looks like there used to be a round electrical box screwed to the wall at some point in the past. This was probably changed to allow a cupboard to be put there as this box was just below.
What is my best option? I would prefer not to have a box sticking out with a light attached to that. Its a plaster and lathe wall so I assume I should cut that out and recess a box there - but what is the best type of box to use and is this the approach I should be using?
Thanks for your help!
Hi, that wiring appears to be old knob and tube, I would install a 4” round plastic old work box, it won’t be easy with the wood lath, if you don’t need a fixture there just install a blank plate and paint it, if you do need a fixture then it will most likely need to have a pull chain switch.
https://www.acehardware.com/departme...it/boxes/32712
Geo
Geo
Yes..... that is definitely knob and tube wiring.
You should be looking to replace that outdated wiring as you make improvements to your house.
