Wiring help, replacing ceiling fan with light fixture
Old 08-11-19, 12:36 AM
We are trying to replace a ceiling fan with a light fixture. The junction box has 1 black, 1 white, 1 red and a bare copper ground. The red wire is always hot and black wire turns off with switch. There was a separate switch for the fan and the light portion had 2 switches. The new light fixture has 2 black, 2 white and a copper ground. It has 4 light bulb sockets.
The first time we wired it , we hooked up 1 black to black junction , 1 white to white junction, grounds together and capped off the red as well as the other 1 white and black on the fixture (per terrible unclear directions. 2 bulbs came on. Next we tried putting all 3 blacks, all 3 whites, grounds together, capped off red, and that tripped the breaker.
We we now have no light and will take a month to get an electrician out. Can anybody help?
Old 08-11-19, 12:59 AM
A
Received 119 Upvotes on 103 Posts
what type of light fixture are you putting up exactly sounds like you may of wired it correctly if you had 2 lights of the 4 working, would really look at the new fixture more closely see how its wired perhaps there is a problem with the new fixture.
Old 08-11-19, 05:42 AM
Received 516 Upvotes on 421 Posts
Should have worked. I suspect you have a defective fixture.
Old 08-11-19, 07:40 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, you could have pinched a wire when you reinstalled the fixture, double check the wiring, also see if it works with the fixture hanging away from the box.
Geo
Old 08-17-19, 12:27 PM
Geochurchi, what does it mean if we "pinched" a wire? How would that affect it? And by seeing if it works away from the box, do you mean to turn the power on after wiring but before attaching to ceiling?
Old 08-17-19, 12:33 PM
Received 3,982 Upvotes on 3,574 Posts
Yes. Restore power before remounting the light as a test.
You could also remove the two bulbs from the sockets of the lights that were not originally working to determine if there is a bulb to socket short.
Old 08-17-19, 12:37 PM
joed, do you mean a defective fixture because it tripped the breaker? Why didn't it trip the breaker with the first setup?
Old 08-17-19, 01:39 PM
It didn't trip the breaker the first time because only half of the fixture was energized. The problem could be in the second half that was energized on the second try.
