Multiple switches, Vent fan
I'm afraid I haven't the vocabulary to do a google search on my own. Here's what I'm doing, and what I need an answer to:
Replacing a bathroom vent fan with a heat lamp. Original brand is unknown. I have a 3 switch wall plate. One to a separate track light, one to the fan and a third to the heat lamp. I assume anything I buy with be plug and play but all inclusive of a single switch. The one I'm probably going to buy has a single mutli function switch (Light/Nightlight/Fan/Bluetooth Speaker)
So, what to do with the third switch?
Can I pop an a/c outlet into it's place? Do I leave the original switch in its place? Then what happens with those wires at the unit? or at the switch? Can I ground it somehow and put a blank plate over it?
You can see how google is no help ;-)
Hope I've come to the right place.
Thanks for the look,
Best regards
Best regards
Top Answer
08-11-19, 10:57 AM
Cap the unused wire at the new fan.
Leave the switch and let people go nuts trying to figure out what it does.
You may not be to put a receptacle in place of the switch depending on the cables in the switch box
