Floodlight on a timer or sensor?
Old 09-05-19, 09:08 AM
B
I bought a ring floodlight and hooked it up. The issue is that there is a timer or light sensor somewhere that is causing power to only go to that fixture during dark hours. How can I figure out what's controlling the power to this fixture?
Old 09-05-19, 09:22 AM
Received 517 Upvotes on 422 Posts
Trace the wiring.
Look around outside for a sensor mounted at the eves.
Old 09-05-19, 01:53 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, sounds like it is controlled by a Photo cell.
Could look like one of these.
https://www.homedepot.com/b/Lighting...vZc7qzZ1z0u58q
Geo
Old 09-05-19, 05:37 PM
B
Thank you Geochurchi. Found a photocell on the side of the house. Would it be smarter to uninstall it or just cover it with something to block the light if I want the fixture powered 24/7?
Old 09-05-19, 06:11 PM
Received 3,993 Upvotes on 3,584 Posts
Cover it first to make sure it's the culprit.
It should be easy to bypass. Remove the two screws from the plate. Disconnect the black and red wires from the sensor and connect together. You can leave the white wire connected to the sensor.
