Replacing the stock switch with a LED latching switch?
Old 09-11-19, 01:46 PM
R
Hey All,
As above, is it possible to replace the stock switch on one of these led tape lights with an LED latching switch?
https://www.lowes.com/pd/Utilitech-96-in-Plug-In-Under-Cabinet-LED-Strip-Light/1000640209
The switches I'm looking at are these as it's for a kids bedroom project
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F283194306908
I imagine it's possible but the simple looking things are often the most complex.
Thanks - Rob
Old 09-11-19, 01:51 PM
Received 3,593 Upvotes on 3,222 Posts
Momentary(Self-reset),Latching(Self-locking)
That description is describing two different switch actions.
Are the switches strictly momentary or do they lock in on one push and unlock out on a second push ?
Old 09-11-19, 02:05 PM
R
They have momentary and latching. I'd be using latching.
Old 09-11-19, 02:08 PM
That's correct.... you would use latching.
You would install that between the plug in power supply and the LED's.
What is the voltage listed on the power supply ?
Old 09-11-19, 04:26 PM
R
Says 12v - 1A so I'm guessing It shouldn't need adjusting for adding the switch.
Old 09-11-19, 04:40 PM
You should be all set. The wiring should be easy when you get the switches.
They should come with a terminal connection sheet.
Old 09-11-19, 05:22 PM
R
I'm now wondering if I could also use this to power a group of these switches in parallel so the kids can turn them on and off for fun without impacting the light strip itself?
I was planning on wirring those up with AA batteries to keep it separate but if it's simple enough to add 10 switches to each circuit I could do that too?
Old 09-12-19, 05:25 AM
P
Received 1,950 Upvotes on 1,746 Posts
Yes, you can have a switch controlling power to a series of other switches.
