8 foot fluorescent fixture problem
Old 09-14-19, 06:30 AM
I installed an old fixture in the basement. However, the lights would not come on brightly.....they were dim and dull...not fully powered. I replaced the ballast and then the bulbs only to get the same result.
What could be causing this problem ?
Old 09-14-19, 08:23 AM
A
Received 73 Upvotes on 66 Posts
Assuming the circuit and fixture wiring is good, the only thing left is the bulbs, but, although you probably don't want to hear this after buying a new ballast, I would either convert the fixture you have to LED's or, since it's just one fixture, maybe just buy a new LED one. As long as you use LED's with internal drivers it's a straight shot for the power, no need for a ballast. Longer life, less power consumption, brighter, and less maintenance.
Old 09-14-19, 09:01 AM
Received 477 Upvotes on 393 Posts
Tell us about how you installed it. There could be an issue with the install.
Old 09-14-19, 01:59 PM
The only issue with the install could be the grounding. I was unable to ground to a pipe....so it was with a screw into the floor joists.
Old 09-14-19, 02:22 PM
P
Received 1,759 Upvotes on 1,572 Posts
You said you replaced the ballast and bulbs. Were both new or did you install a used ballast and bulbs?
Old 09-14-19, 02:28 PM
Tolyn Ironhand's Avatar
Received 672 Upvotes on 570 Posts
How is grounding to wood going to work? You should have a ground path in the wiring.
Old 09-16-19, 06:38 AM
A new ballast and bulbs were used in the replacement.
Old 09-16-19, 11:49 AM
P
It is possible the new ballast is bad but first I would double check your wiring. Especially, if you were converting from an old magnetic style (heavy) ballast to a more modern electronic one.
Old 09-16-19, 11:55 AM
F
Rapid-start fluorescent lamps REQUIRE a grounded, metallic reflector (or similar) within one inch of the tubes for reliable lighting. You need a metallic connection from the reflector to an electrically grounded metal object or back to the circuit breaker enclosure.
Running the grounding conductor to a piece of wood will do nothing.
Old 09-20-19, 04:05 PM
Thanks for that Furd. I connected to an old junction box that only had 2 connectors. There was no ground wire connection. I wonder if I connect the ground wire to the box or to the copper plumbing ?
